When you get a chance post a pic with the bed full raised. I'd like to see how it is set up.
I would just swap the hinge,pump, cylinder onto your army truck.
That's completely different. That's a heavy insert not a built in scissor and hydraulic cylinder/pumpya that was the 1 thing i noticed with the insert in my truck was the weight i was lugging around a lot when i wasn't using it .
I appreciate both options and I'm still debating both options. Either way I need a bigger tractor to load it. So I have some time to decide. I could always build a different rig as a wheeler as well. I have no shortage of options, that is for sure.That's completely different. That's a heavy insert not a built in scissor and hydraulic cylinder/pump
I have had two different dumps. My k30 dump truck I have now. And I had a 78 k20 I put a dump on.
Can understand what your saying, but the weight isn't much. The usability of the dump far outweighs the weight concerns. At for me.
I look at it like this. Think about cleaning your horse pens.
Grab the truck. Load some horseshit and drive to the dump spot and dump.
Or hook up a trailer, load, dump, unhook. Small time difference I know but can be appreciable depending on how much you use it.
My 02.
