[ QUOTE ]
With 4.10 gears and Boggers, I don't care what you got for a motor, the instant your engine drops RPM almost 50% that it takes to get from 1st to 2nd gear in a 700, it's going to bog.
[/ QUOTE ]
I don't remember seeing what he had for gears, but with a 500hp big block, I don't think the boggers will cause it to bog down, unless he was running 3.73 or higher gears, or unless the other truck was also digging in and had good traction.
[ QUOTE ]
I disagree. You're not going to be able to pull 2nd with another rig yanking on you no matter what gear/range you're in.
If you were in 4 high you would lose even before your tires spun.
[/ QUOTE ]
I disagree with this, I've seen trucks get second gear before in a tug of war, I think a 500 hp truck will do it fine in low range, unless the other truck is pulling him (has more traction). Granted, with the sm465, shifting will not be a good idea as you can't shift quick enough to maintain your momentum, the other will regain traction, in the time it takes to shift.
Just my opinions on the matter. /forums/images/graemlins/thumb.gif
