UD Spring plates! These can be had for pretty much any axle/Ubolt configurations. Pictured are for the GM D60.
Little bit about the plates,
They are made of 1/4" thick steel. 45* bend on each end which stiffens the plate as well as creates a nice radius to ride against your spring rather than a sharp corner which will introduce a stress riser on your main leaf. Bad place for a stress riser. The plate is also boxed on the sides to stiffen it on the longitude. So, with this combination of bends and reinforcement it is much more rigid overall and comparable to thicker material without the dead weight. The center pin hole is slotted which will allow for the use of offsets.
On to the pictures.
These sell for $37 a set for most any applications such as 14 BoltFF, D60, HP60 flipped. Might be a bit more if you are looking to put a really huge axle under your ride. I'm sure there are some really large plates out there.
Be sure to reply to the giveaway here;
Giveaway clickety
On to the pictures.
Giveaway clickety
Not what I meant. Really!
