That looks awesome man, good job!
I was wondering if there was anything going on with your build lately. Now I know.
I was wondering if there was anything going on with your build lately. Now I know.howdiy said:How long did it take with the torch?
Also can you get the 64's of a 2WD?
Looks like I'll be doing it then. did you have to move your front mount? On my truck It doesn't seem like it will work as well as a blazer.mostwanted said:Didn't take long at all with the torch![]()
The 64s that I have came from a 2wd from a junkyard.
mostwanted said:
mostwanted said:
. I decieded to tweak the body mount a little and drill out the rivets. Worked out pretty well. The front springs got moved to the other side of the body mount as was described in the technical article.Craig Artzner said:So did you get all the por-15 off your hands yet?
It'll work. The cool thing about black trucks is that even if you goof up the cutting slightly, it's harder to notice against the wheelwell 'cause they're both black.mostwanted said:I cam up with a trim pattern. What do ya think?
