K5MONSTERCHEV
Re: Who all\'s injected? Finally got it!
Another thing I did was get a newer oil pressure switch/sender. About '91 or so on the trucks, (and about the same time on the F-bodies) GM got smart, and combined the oil pressure switch and sender. The combo piece is smaller than the stock oil pressure sender by quite a bit. This piece wouldn't fit next to the distributor like stock, so I ended up putting it above the oil filter. I grabbed the wiring plug for it out of the wrecking yard, some FWD car as a matter of fact. All three wires were the same color as what were in the F-body harness. /forums/images/graemlins/smile.gif
The car I got the TPI off of has that in the block. Guess ill take it and use it, no sense to T into my oil pis line if that will work.
