Using zero rate to move only oneside of the axle foward?
Status
Not open for further replies.
howdiy
Fl
Fap fap fap
I wouldn't do it, you have something tweaked. The frame, frame, or the frame is my guess. I you move one side fwd, I would think you are making a death trap for the hwy.
sounds like a tire-eating nightmare waiting to happen...
fix it right.. find a bodyshop with a frame machine, have em measure it up and put a pull on that rail... not as expensive as you might think...
Not to mention one side will be higher.
Wow man you are nut's. First fake beadlock's now a zero rate on one side....:haha::doah:
You need to fix the real problem, not try to slap a band-aid on it.
I would try to find out what is wrong first. if you have a broken center pin thats any easy fix. what 2 points are you measuring from to determine the axle is crooked?
You may want to change your profile:whistle:
Biography:
Awesome at everything
Get some help from someone that can help you correctly diagnose what is wrong before you go driving around on the street in a death trap waiting to happen. Most body shops can pull a bent frame for a couple hours of labor if that's what it needs.
[fap fap fap
fap fap fap
This should be a good thread to watch. I don't think we have had one with this much potential for quite a while. Mods, please don't lock this one too quickly - I'm in need for some entertainment.
I measured from the rear end to the front end
And it also rubs the fender on one side and not the other
You can even see that the axle isn't straight
I also love how all you think your almighty
Why don't we have a focking popcorn smiley!!! And no I don't want to focking link one as a pic so fock you! Because I know some bastard would do that as soon as I asked...:rolleyes: :haha:
Center pins are cheaper then zero rates... that might be the problem. If you don't want advice, then don't ask, it's that simple.
I have brand new springs and center pins. It did it with the 8 inch springs and the other springs that was on it before the 8 inch springs
I kind of want to say no but I'm not really sure
Something is way off
The cab is rusting out also
Anyways I've been having a bad week :haha:
how long have the springs been in. did you do just fronts or are the rears new too. measure each spring eye to center pin. I'm guessing you have one spring installed backwards.
Status
