Want an On Board Air System for $25??? :-)
It is like 45$ for shipping alone to you up in Alaska.
It is up to you if you want it, but I got one this weekend.
Eddie
what shipping service are you using? USPS? Is there a FedEx or DHL around you? I ship things of simliar size across country for $8-12 with DHL..
Rates get a LOT different when you have to cross borders of countries. :(
Ill never use fed ex ever again, they have lost several packages in the past couple weeks.
That was using UPS, using their web site.
Not sure about the others.
Eddie
looks like DHL to you is 28.
I dont know how well they are, never used them, because the local driver is the guy my ex wife was having an affair with.
Eddie
i went to the local pep boys and i guess i ended up getting the 50dollar one... no 30buck ones there... oppps oh well it rocks though, i can fill my tires up damn fast.. i like it.
well in the jeep I have a 4000 psi nitrogen tank, airs the tires up pretty quick.. :crazy:
thanks not a bad price though for that, hell if it last and doesn't burn up its a great price :thumb:
Well, finally got a photo......................The pressure switch works great, kicks the pump off at 110 psi.
Sweet! I think that perhaps a bit of high pressure rubber tubing between the pump and the switch is in order though. On long runs that pump gets pretty hot. Those brass fittings will do an excellent job of transferring the heat right into your new switch... :eek1:
nerraw117 said:
can you still order these from the net somewhere? i cant find them at any local stores.
They were a closeout deal at Checker, so when they're gone, they're gone. However, you can still buy the same compressor at Pep Boys, but their regular price is around $70. 4 Wheel Parts also sells them now, also for about $70.
