General information for drilling and tapping cast iron
Please do, thanksI can check my bolt length later today.
This is what I need? It says bottom finishing tap. This one is tapered and they have one that isn'tAn industry standard ( they are variables and exceptions ) is 1-1/2 thread depth engagement of the diameter of the retaining hardware ;but you are working with a limited amount of material until you possibly make it a through hole instead of a blind one ( blind hole is what you want but I think there is enough material there to keep ya safe ).
You can mark off the proper dimension on your drill bit with tape as a guide to keep you from drilling to deep.
Also keep in mind that the tap you have there is not a bottom/finishing tap and the very bottom of your engagement will not have proper threads - but if you have enough hole depth to drill a little deeper than what thread depth is needed all will be well.
Keep in mind that a machinist shop can do this for most likely less money than acquiring another drilled case plus freight charges ( you had mentioned this in one of these post lately ).
Also don’t let this give ya’ a headache - if you are not wheeling hard where sudden high traction and plenty of frame flex is the plan than this bar is not a 100% necessary.
That being said I am a fan of these bars in any 4WD but on the average user most cases it wouldn’t matter if they were there or not. I think they are good insurance and effective but don’t be afraid of light wheeling without one.
Yes... I'm going to drill 3/4 which seems to deep, and see where I'm at. Maybe 1/2 inch but that doesn't seem deep enough.Remember, that’s the bolt length not the hole depth. Part of the bolt length will be eaten up by the thickness of the bar and a lock washer.
You are only looking at the external boss only - there is also an internal boss as well.Yes... I'm going to drill 3/4 which seems to deep, and see where I'm at. Maybe 1/2 inch but that doesn't seem deep enough.
I've looked all over online and can't find the actual depth of the hole on 205 for that bolt
Just for reference this case is a non drilled unit from my beloved old 77 K/10 that had a 465 in front of it - It had a build date of August and so did the truck; must have been cutting production delivery times real close.Yes... I've seen one pic of the inside from the guy who just drilled all the way through the 205 to mount the strut rod.
Haha. Well, at least for whomever needs this info it will be in this thread, instead of all the place where I've had to look. Hahahaha
Ordered the drill bit and both taps...
Brother...!!!! Thanks a million. You may have shaved a few more pages off this thread with that info.
Hahaha, your welcome. I’ve been following along and meaning to get under there for ya.Brother...!!!! Thanks a million. You may have shaved a few more pages off this thread with that info.
