Weighed the tow rig/truggy/trailer today
70~K5 said:
I driven trucks with a V12 detroit desiel. I've driven trucks with a 3408 cat engine.
I've drive trucks with about every I-6 diesel used in class 8 trucks.
I've driven trucks with allison auto trans.
I've driven trucks with 9,10,13,15, and 18 spd roadranger trans.
I've driven trucks with 4x4, 5x4, and 6x4 manual trans. (4x4 is a 4 spd main trans and a 4 spd aux trans).
And I've driven blondes, brunettes, and redheads.....whats your point?
The point is with Joe's truck being 2wd he can't use the transfer case's low range like you can. He may find there will come a time that his first gear isn't low enough. I've been there and it isn't pretty. How are your dad's OTR trucks set up? If "gear fast/ run slow" with 2.73s to 3.08s sometimes trying to move a heavy trailer in a bad spot can be trouble because you don't have a low enough 1st gear.
ALmost all of our trucks are geared with 4.10's. We run mostly 2 axles locally hauling agriculture and aren't built for out of state running where the speed limit is higher. THis is California, 55mph or a ticket in hand. :)
Goddamn Bruce. We are NOT talking about your "Pete".
There will never come a time that I will need more gear reduction. It's a 3/4 ton truck. Not a big ass semi with an 80k lb load cap. I'm never gonna be pulling more than say, 9klbs. Ever. This truck, and that weight,with these gears, or even the 3.55's will move 9klbs in any situation I'll come accross just fine.
Have you been there with a 3/4 ton diesel truck and a 9k lb trailer? Of course you haven't. It won't happen with that combination. If it were a 302 sb, auto trans, 3.55's, and that load on the trailer then you'd have a point. Or if you had a "Pete" with 85k lbs on the trailer and needed tro manuver in some tight uphill situation...But niether of those is the case, right?
I've pulled loads grossing around 80K with a ford gas engine and a 5/2. 5 speed trans, two speed rearend.
So?
I've driven a 65 ton M1A1 tank with an Allison auto tranny. My tank driving experience, while it sounds cool, has nothing to do with the discussion at hand. Your truck driving experience is impressive, but has nothing to do with the discussion at hand. Have you ever towed with a Dodge CTD truck? Thats a yes or no question. Not, "No, but I have driven/towed with xxxxx". You're quoting all your truck knowledge/experience in a effort to make people think you know what you're talkin about. People already know bruce, give it a rest.
It will spin 3K? Someone changed the governor already for you. Stock 12v's are set at 2500 RPM's.
I've never hit 3k cause I don't like to be that close to the redline. But definatley been higher than 2500...2800 is as high as I've been. When I said it redlines at 3k, I meant that the numbers on the tach turn red at 3k. :p:
KidJethro said:
So?
Ditto. Know one cares what anyone has driven unless it's the same vehicle at hand. I HAVE driven and towed with my CTD including a loaded truck that was 79K gross. I had plenty of power but was also in 4low. With 3.55's you'll have plenty of low end pulling power and since it's 2wd I would bet you will run out of traction trying to pull something before you run out of power.
Bruce,
Your Pete with 4.10's is geared close to my dodge with 3.55's. YOu have tires that are somewhere from 37-40" tall tires vs. my 31" tires.
Well I don't know. The gov. is set on 2500 on those trucks stock.
I've driven several different types of tracked vehicles, one in particular with a 600 HP Cummins V8 and an Allison trans as well. I must be the expert on towing with Diesel powered pickup trucks.:haha: :haha: :haha: :haha: :haha:
Glad to see we finally agree on something. :grin:
Joe I've driven a couple of Dodges with CTDs. I didn't own them they were owned by friends of mine. You may never need a lower gear, then you may find that at some place you do. But do what ever you like with your truck. Can you lock out 1st gear and start in 2nd? If so hook up that trailer with your truggy on it and try it out. See how it pulls from a stop starting in 2nd gear. If that works for you go for it.
I just went to Dodge's web page. They list tow ratings with 4.10s and 3.73s. they don't list a tow rating for a CTD equiped truck with 3.55s.
You are very much over exadurating. Having 3.55's and starting in 1st is lower than starting in 2nd with 4.10's. The difference between the two ratios in question is not THAT big of a difference, especially when you add in the low end torque of the 6BT/ISB engine. You are over reacting about the difference between the two ratios. I own an '01.5 with 3.55's and have ridden and driven in a few other Dodge CTD's. 3.55's are the only way to go unless you plan on a 35" tire or larger (which would then equal to having 3.55's with stock 31's anyway). 4.10 geared Dodges are worthless with the automatic. It is just geared too low for acceleration, especially unloaded. 3.55's are plenty low with stock tires with an auto. With the 6 spd manual you can get away with the 4.10's but an auto truck is what I'm focused on since that is what Joe has.
Don't pull a Dirtwarrior on us and continue to argue. :grin: :laugh:
I take it you don't know dodges very well. IN 2003 they went to a 3.73 and 4.10 ratio. With second gen trucks like mine and Joes it was either 3.55's or 4.10's. Most rolled out with 3.55's.
It's useless. Just put him on ignore so you miss his occassional attempts at starting trouble with people his pissed off in the past............
Well what it doesn't say there is that 4.10s are no longer offered in a manual trans truck.
I've been keeping an eye on this thread just cause I like to read about diesels... I think what 70k5 originally meant to do with listing all the diesel trucks he's driven is to prove to Timmy that he knows alot about diesels... Not to brag or anything. His post was in response to this:
84_Chevy_K10 said:
Forget everything you know about gas trucks when referring to the Cummins. It redlines at 3,200 RPM. I drove a 4.10 geared, 6 speed Cummins truck and I instantly knew that 4.10s were not for me. The narrow powerband and close ratios of the 6 speed resulted in an obscene amount of shifting.
I opted for the 3.73s as a result. 3.55s would potentially be even better--especially with the shorter tires like Joe has.
I could be wrong though...
You're right, thank you.
