andyblack
Registered Loser
The stock TH700R4 in my '85 shortbed pickup went out this week. It had been sounding worse and kinda slipping for a couple of days and when I backed out of the driveway and put it in drive, I heard a loud BANG. I started driving down the street and when the trans shifted to second gear, I started hearing some awful grinding and ticking sounds.
I don't really want to repair that trans though because I've had it leak and burn fluid and stuff before. My dad says to go with a TH400. He's rebuilt literally hundreds of them and has all the stuff to build one up for me. What I don't know about though is all the stuff involved in a swap like this. I used the search function and found out that I should be able to use my old driveshaft (as long as I use another NP208 t-case) and that I would need a 32 spline NP208. I know it's possible to swap the input shaft on the case from the current 27 spline to the required 32 spline if I have to. What else do I need? Will my old crossmember work? I read that the TH400 is only 3/8" longer than the TH700R4, so I guess my driveshaft will work. What about shifting? I don't think the 400 will need the TV cable like the 700 does. So what does it need to shift? Is it electric or vacuum operated or what?
I guess my main concern is my engine. It's the stock 305. Will a TH400 bolt up? Or do I need a regular 350 engine? I have so many questions but I'm sure some of you guys know all about how to do this.
