Welding 101 tips and tricks.
It's two different plugs. One is the welder the other is the dryer. At my house I have both of them and don't want to cut the end off the welder if I can avoid it.
how long is the run from the welder to that 30amp dryer outlet?
I'm thinking a home made extension cord is in order. The input on the welder says 20 amps.
Well actually the welder requires a 30amp breaker, the dryer is on a 30 amp but the plug is different.
This is driving me nuts. :haha:I went to home depot and they don't have the goofy extension cord I'm trying to create. I was thinking about building a "junction block" that I could toss on the ground. Home depot has the wall receptacles but not a cord end.
think you got it hard with 220 .
toss in 3 phase
and old school stuff called wild leg .
that will make your head spin just a bit more. :haha:
Check out Eastwood tools, they have a nice 175 amp 220v, has a three year warranty also comes with a spool gun for aluminum. I think it is around $600 give or take. I've been welding since 1960 as a structural Ironworker, am planning on a new small welder think this will be it.
I'm 73 so I've got a lot of time behind a hood.
yah just get a 2 gang box, put the wall mount plug on there. Its not recomended but I just jump one of the legs and the neutral over to a standard 115 socket. So I have 230 and a 115 outlet.
A aluminum gun would be sweet to get but first I need to learn how to use this thing. :doah:
I used a 2 gain box and made up a extension cord, works like a charm I cranked the welder up all the way and it never popped.
Now it's time for you all to laugh, I had the gas tank around 18 and between 1500-2500. I just took a guess off reading something. I'm having trouble keeping the tips clean and having the wire from breaking. I would assume this was from the tip and my angle.
I did knock that side with a hammer to "test" the weld...
oil free surface
practice x10 million .
and nozzle dip keeps tip clean and wont mess with the welding .
if welding with any sort of air movment like fan / wind it will blow the gas away from the tip and mess you up .
and unless body work I would skip the aluminum spool gun . there not the best at all for structural stuff. for that you need a tig to realy get the heat in the stuff.
I have a can of some kind of cleaner I would assume that would be the nozzle dip.
Would that be the reason for having the problem?
Was pushing, and about a half inch or 3/4 away form the material.
I talked with dueling and he said tried to pull and get closer.
Angle iron works well for practicing. Go until you fill a 8 or 10 inch long section.
Make sure you can see the puddle and the wire. I can't tell if your on a table or floor, but if you can't see what your doing you won't get it until your really good.
Make sure you have a puddle going before you start moving. Don't worry about weaving till you can run stringers.
