BlazerBud
I have to weld some new brackets to my rear 14 bolt axle for the shock absorbers. The previous owner installed the axle, removed and ground down the mounting brackets for the shock absorbers. Not sure why, I think that they may have been in the wrong locations.
I can weld really good, but I have never welded to an axle housing. I was going to fabricate some nice brackets, then weld them on. I have seen lots of axle welding write ups mostly for suspension mods.
My concern is about the heat. Is it bad to weld to the axle while it is installed? Does the heat damage anything inside the axle housing. I don't plan to burn through, but does this char the oil inside?
I have several welding machines and can do any process. I was just going to flux core wire feed this so it would be shallow.
Any suggestions?
Any suggestions?
