vandelay industries
Let's say the factory is (i don't know what the factory tolerances are) let's say .02"....07" etc. That's fine. i'm not talking about that.
But we're not talking welding a small .125" thick shock tab on a rear. Welding two leaf spring perches or 4-link brackets is going to take ALOT of heat and time---at least one minute total of welding per side.
This likely will cause the rear to go out of alignment beyond factory specs. i'm afraid welding for 1 inch at a time, letting it completely cool off then welding another inch etc. won't avoid this problem? Now, IF, on these larger rears with thicker tubes (14bff etc) they aren't affected, then fine. i work with 10 and 12 bolts.......
i don't mean to be anal (although i am), but it seems like welding mounts on a rear is more than just cutting and welding. It's cutting, welding AND straightening.
i thought CKers do it the right way? This tool-----will it really cost $700 to straighten a rear?
