Suposedly they go static, never close, but they already do that from factory? There's a conversation about it going on including BPW and fooling ECM at other site.Well your not supposed to go above 100 but if you add VE Main and VE adder in STOCK 1227747 they are above 100...
When this happens when I tune I raise fuel pressure and start tuning.
Is this only happening WOT? Have you tried adding some PE?
Anyway, I considered that it could be sucking air. The clamp is pretty tight on the filter. Maybe I'll snug it a little with everything running and see if I can see any difference in the bubbles. The next interface is at the sender which might be tough to access.
