A ton lower than a 350, and the curve is close to dead flat unlike a sbc. I've had both, and torque wise there is no comparison.big_truxx said:anyone know the peak rpm for tq on the 6.2?
Rene
i'm seeing the peak at 2000 rpm on the dyno for gassers... was curious how much lower the 6.2 peaked for torque. id really like to see a curve for hp and tq on the 6.2
.What?Im gonna agree with RJF (eek!)
I usually have decent advise, I guess.
joez said:.
about the early fords. The 6.9's cavitation has been blown out of proportion more than the "Killer dowel pin" in the dodges tranny's. Head issues are just like the 6.2's, if you reuse the head bolts, you are gonna have major problems. The 6.9's are good motors, and put out a decent ammount of power for being a N/A diesel.
As for the 6.2's towing, i have towed with mine, and while it is a dog, it still gets the job done. I loose a lot of power with my tranny and gearing, but it still tows. No, it will never be a D-max, but my mild N/A 6.2 does fine for what it is. Steve, if you can, i would look at getting either an early ford, or a CUCV chevy. While the dodges are stout, they are more expensive as of late because of the "Bombing" craze.
And there is no way a 6.2 has 355 ft/lb of torque. My buddy with a 7.3 N/A will walk all over my 6.2, and he only has 380 ft/lb of torque with the same HP as me. He has way more power than i do, and my 6.2 actually has a few tweaks done to it. Id say 280-300 is a good number. it doesnt have 355, but it also doesnt have 240.
i just took the power leather seats that someone had once put in my 84 crew out in favor of a bench.
just my personal taste.
so how does the gen thing go on CTD? and are the older cummins any good the ones before the CTD? did i read right in that the 1st gen CTD started in 89? also were the 1st gen CTD mechanical injection or what?
the 3208 used to go for $3500 around here in maine and i never got to pricing the 3116.I read someones post earlier about how they can haul! But they sound really heavy. Also, I doubt I would beable to find one anywhere close to me, especially for a good-not bad price.big_truxx said:just a side note; if you could afford the project a CAT 3116 I-6 swap would really rule steve. followed by the CAT 3208 V-8.the 3208 used to go for $3500 around here in maine and i never got to pricing the 3116.
What does the ford have behind them? You think if I can find one it would be better than the GM? I will keep my eyes open for the ford 6.9 diesel too then. Then when I do find either of them, I will update and ask if it's a good price and all that. Until now, I will just keep reading everyones responses.f I were in your shoes Steve it is as simple as this....
Forget a gas engine, they suck way too much gas and don't pull as well as a diesel, period IMHO. I'd rather have a slow 6.2 than a gas eating 454 that might get me to my final destination over say a 100 mile trip 10 minutes sooner than a 6.2 would. Is 10 minutes worth twice the cost of fuel?
If I did not want to spend a lot of money on a tow rig I would look for an 80's ford F250 or 350 first, the 6.9 na motor first came out in '83 IIRC and is considerably more powerfull than a 6.2 GM. Had a decent drivetrain behind it too. Then i would look at an 82' and up 6.2 GM. I would choose an early first gen CTD preferably but '89 was the first year for them and would probably cost fairly more than the early Ford or GM.
Don't worry about dyno numbers or peak torque numbers, yada yada, Both the Ford and GM will get any load to where you are going just fine, the ford probably doing a little better. It's as simple as that.![]()
Also remember that you have the option for a newer rig too if you can afford it. I wanted a newer electronic CTD that is a lot nicer truck in and out than an earlier model. I put down what I would have spent on an earlier rig and financed the other half and am making a relatively small monthly payment for a little while. If you can afford a monthly payment for a while then that is definantly the route I would take. You will praise yourself down the road while sitting in your nice compfy powered leather seats cruising over hills passing people with the trailer and K5 in a much quieter, nicer truck.![]()
I agree with you, but I meant when comparing engine to engine, rear wheel power does not matter. For example, if you are comparing a 350 to a 6.2 in a factory configuration, you do not compare the chassis dyno numbers of a 6.2 to the GM rating of a 350, or the GM rating of a 6.2 to the chassis dyno numbers of a 6.2, its apples to oranges. So, just because fourwheeler did one test, where if you notice the engine in factory trim made 272 ft lbs. and only 94 hp, does not mean that the GM ratings are estimated and not valid in my opinion. In fact, it says to me that the 240-270 ft lb ratings I have seen are quite valid. What the fourwheeler test also shows is how big a gains you can get by doing some pretty simple things to make the engine run better. I hope I dont come off as being argumentative, I am just trying to assure that the information given out is as accurate as possible. I also do not want to sound like I am badmouthing the 6.2, I own 2 of them and I think they are an awesome engine for offroad or tooling around town, but I think they are underpowered for towing unless turboed which would probably put Steve over what he wants to spend.I disagree, because what's getting to the ground is what you feel and what is doing the work. Nobody questions chassis dyno number on any CTD truck or D-max truck when they're posted, yet this dyno sheet is treated as if it's pure fiction. The Banks graph is more conservative but is an illustration, not a dyno sheet.
If we are talking pre-powerstroke, inline pumped Cummins (94 and newer), 6.5s, and duramaxes, then yes, that would be true.So in the good-okay list, it goes dodge, ford, then GM for pulling power?
The ford used the venerable C-6 transmission. It is basically the th400 for a ford with the C-4 being in the 1/2 tons like a th350. They use a Sterling rear end that I am not a huge fan of but is a decent rear end, ford still uses them today. It comes with a 10.5" ring gear and in both SF and FF versions. Basically the same strength as a 14BFF. Up front is not all that great but it is adequate, D44 TTB setup. Not real strong but you would probably never have any issues with it as long as you didn't lift it or wheel it.(it's a tow rig right?) My grandpa has 250,000miles on his '95 power stroke ford that has the same front D44 TTB with no probs. T-case is probably a Borg Warner, good box.84gmcjimmy said:What does the ford have behind them? You think if I can find one it would be better than the GM? I will keep my eyes open for the ford 6.9 diesel too then. Then when I do find either of them, I will update and ask if it's a good price and all that. Until now, I will just keep reading everyones responses.
Don't rule it out, you could even come up with an older '94-'98 dodge 12v CTD for somewhere around 10-15K(U.S.) depending on mileage which is cheap IMHO when it comes to a diesel powered 4x4. You might even be able to drop back down into 4 digits on the price if it is a 2wd early '94-95' cummins dodge. Plus people like to dump high mileage trucks for cheap and the cummins will last for 1/2 million miles between rebuilds.Oh, and I definitly won't beable to get a newer rig. Way out of the budget
I would say definanlty in the older trucks and I say it is roughly still the same way..
Yep, heated black leather seats. I wouldn't take anything else.big_truxx said:leather seats?i just took the power leather seats that someone had once put in my 84 crew out in favor of a bench.
I have looked into a cat swap myself since I am a huge fan of cat engines. I wasn't interested in a mechanical 3116 or 3208 but I was very interested in the newer 3126/C7's that are electronic and more powerful. Cat wanted over $10K for a crate 3126 and then by the time you mate a new Allison behind it I said forget it! I wanted to put it in an '89-91 Crew cab SRW 1 ton 4x4 but after punching numbers I would decided to go the cheaper and easier route of buying my '01.5 dodge cummins. Less money for the D/CTD than the GM/Cat idea with a nicer, newer truck and a warranty.just a side note; if you could afford the project a CAT 3116 I-6 swap would really rule steve. followed by the CAT 3208 V-8.the 3208 used to go for $3500 around here in maine and i never got to pricing the 3116
There is nothing wrong with a spirited discussion, as long as it stays on topic and respectful...which it has. This forum was beginning to put people to sleep, but this post has been very active (and fun).BlueBlazer62 said:I agree with you, but I meant when comparing engine to engine, rear wheel power does not matter. For example, if you are comparing a 350 to a 6.2 in a factory configuration, you do not compare the chassis dyno numbers of a 6.2 to the GM rating of a 350, or the GM rating of a 6.2 to the chassis dyno numbers of a 6.2, its apples to oranges. So, just because fourwheeler did one test, where if you notice the engine in factory trim made 272 ft lbs. and only 94 hp, does not mean that the GM ratings are estimated and not valid in my opinion. In fact, it says to me that the 240-270 ft lb ratings I have seen are quite valid. What the fourwheeler test also shows is how big a gains you can get by doing some pretty simple things to make the engine run better. I hope I dont come off as being argumentative, I am just trying to assure that the information given out is as accurate as possible. I also do not want to sound like I am badmouthing the 6.2, I own 2 of them and I think they are an awesome engine for offroad or tooling around town, but I think they are underpowered for towing unless turboed which would probably put Steve over what he wants to spend.![]()
.heh at the price tag of 2.5k yeah maybe a lil over budgetBlueBlazer62 said:they are underpowered for towing unless turboed which would probably put Steve over what he wants to spend.![]()
So it must have been a diesel. It looked real good! It was crewcab but just SRW instead of DRW (It's amazing what I learn, I just realized "SRW" stands for single rear wheel... I always wondered what it meant, but didn't want to ask
so... imho its not worth it unless you really have cash to throw at it. i see in my own eyes being worth it to save the little extra cash to go get a used CAT engine for a swap. not too sure what current market for the CTD is in my area. i think they are more expensive than i would want to bother with for the afore mentioned reason. just saw a 93 2wd dodge w/ diesel for $4,000in my area... not exactly in the cheap club for taking a motor out for a transplant IMHO. I am also thinking about a diesel swap in the future. there is a lot for me to think about. like is it really worth the time effort and $$ i would need to do it? since i know that the gassers i currently have in and running in my trucks will haul loads...
i still LOVE diesels and would love nothing more than to put one or two in my rigs. but you are in a slightly different situation than me steve. you are looking for a rig to tow. i already have two. but for the money i paid i couldnt say no to either. and doubt i would have been able to get even a 6.2 equiped rig for the prices. my 82 has 84k orig miles on it with mr goodwrench that has 24k. silverado with no options and is 2wd but i plan on making it 4x4 after house is built. still, $2,000 and already setup to haul my gooseneck. been REAL good to me and had no troubles with it. my 84 which will see the road one of these days, (brake lines need replaced and im workin on budget for my house so its on the back burner) but even with bad brakes... 20k on a rebuilt 454, was converted to 4x4 before i bought it but even still has a 465/205 behind the motor... even though it only has a d44 8 lug.... i only paid $1,000 for it. both trucks are crew cab dual wheels. so... with that all being said... i basically bought both trucks for just over the cost a turbo for a 6.2 would cost... thats why i could not commit myself to go the turbo route w/o a lot of "spare" money to throw into the project. now im no expert but i have been told that the turbo 6.2 puts out close to 400tq. which IMHO for the $$ spent isnt worth it as you can have much better for just a little more.
