BlueBlazer
- Joined
- Feb 15, 2001
- Posts
- 1,940
- Reaction score
- 1
Estimated from where? Chiltons says 240 for the C code, Banks site says 265 (they do not specify C or J code). Some posts from the archives (by arveetek)back up these numbers. I find it hard to believe that 100 ft lbs is gained on a chassis dyno.Those are estimated ratings Tyler
Edit: I reread what you said about GM's ratings being estimated and I will tell you that when we (Cat) put out an engine, our ratings are not estimated, they are within 1% of advertised power and I should hope that GM was just as precise or at least close. If not, it is not only unethical, but probably against the law.
I did not realize this was the case. I was under the impression that you guys were close enough to the border that anything we had down here you guys could get up there.Regardless, CTD trucks here are not as cheap or cheaper than the 6.2 trucks. We don't have a huge selection of rotted out late model trucks dragging the values down.
had i known what IIRC meant i would have used that in my first post.
so in cant compare the "dyno results" here. so it all depends on what type of hauling you want to do. serious hauling may be better of with a 454. while a mr goodwrench 350 will do ok also. i haul with a 20' gooseneck hooked to my 82 and its not that bad. and i believe i have 3.73 in the rear, this is also not tuned right with an exhaust leak in 2 places on the drivers side
but she still does well. the 84 isnt on the road yet. (brake line problems) so i cannot tell you how that one hauls yet. but i know how an 89 crew dually with 454 tbi and auto trans running 4.10 out back will haul: 70 mph up hill loaded
so i cannot. i hear good mpg reports being 17ish but then i also hear hauling reports not quite as impresive from a diesel as most would expect. yeah 17mpg better than the mr goodwrench thats got me 10mpg but.... also means lacking the torque i do now with a basically stock engine. i have edelbrock intake and a holley carb but the engine is a stock mr goodwrench. so there ya have it my 5 dollars worth for the day
look at mr goodwrench 350 specs Steve. if its something to haul on a budget then for the money initially invested almost twice as much hp and more tq with a mr goodwrench 350 setup over the 6.2 diesel. 250ish hp and 350ish tq at low costs. and if mr goodwrench 350 is harder to get in yer area used and whatnot, can always throw in something like a summit 1102 SBC cam. summit cams run $60 by themselves and it puts out a lil more power than a mr goodwrench cam. also a port job and bigger valves on a stock set of heads make a good difference. headers obviously help. i havent priced machine work on heads recently, but i am fairly confident that you can find somewhere to do that reasonably in your area. also compression is a factor. you, as i know would like to rebuild an engine or two, so why not throw in a set of new pistons? if you can afford another couple hundred on a rebuild itd boost your compression making you more power. but to look at it from a budgeted build/rebuild point of view, a 350 with stock type heads, maybe an edelbrock intake and carb or holley if you preffer, summit cam, with headers at an 8.5:1 comp ratio, yer lookin at 284ish hp and 363ish tq. thats stock rebuilt 350 with aftermarket intake, carb and a cam. nothing super fancy or exciting but it'd get the job done well.
yes acceleration and towing are different... but the mil stuff didnt like ot tow a lot either
