pma4x4
AKA Yankeeroad
Yeah the pinion bearing was like .0something larger but I think externally its the control arm ears.
And the lug count....
Oh wait. I made a typo. It should have read $5.00 instead.I wouldn't pay $500 for a set of 3/4 ton axles that had a semi floater rear axle. $400 for what you are looking at is a better deal if they do have crossover.
Martin
Is that better for you?
Crossover is a couple hundred on its own even used. So you got that working. After that you are paying A hundred per axle and You can't get a gear and install kit for that much. I'd they are gone through check the gears as you said and the ball joints and steering links should be tight too. Spin the rotors and check smooth rotation of Everything. When you open it you will see what lockers are in there. 12 bolt stock would be a limited slip with clutches. If you see gears and separated side gears it will b a auto locker and stronger. Would be nice to see a Detroit in there. 500 bucks on its Own and you get a stronger carrier. They should All bolt in. 1/2 ton pre 73 was skinnier axle Perch same as oneton rear. I believe they were same up front. So you should be fine there. Other than looking for leaks out the axle tubes and all thats about it.
The car and truck 12 bolts might as well be two different rears considering there's gear differences. Car 12 bolts will be way narrower and have 4 link brackets. Truck 12 bolts will be wide and either have spring or truck arm perches.
I've always heard that the car 12 bolt is far superior to the truck version but that could be a.comparison difference of power vs tires.
Oh wait. I made a typo. It should have read $5.00 instead.Is that better for you?
Axles are worth what anybody wants to pay for them. All depends on their wants and needs.
You can't fault people for trying to sell 3/4 tons for $500 because they probably would like to make some kind of coin off them and its highly likely they're not gonna just give them away for free. Hence the quotes above of axle prices being what a buyer would pay for depending on their wants and needs. Its all about supply and demand. In your case, while the supply is out there your demand isn't met because simply the rear is a semi-floater. Doesn't mean you have to bash on that simple little fact because theres probably more people than you think that are actually looking for that specific rear. Why, you ask? Ever think about converting the front 10 bolt over to 6 lug and then getting wheel spacers/adaptors to convert the rear to 6 lugs? Think about that one for a moment. Such said axles would still be stronger and beneficial over any 10 or 12 bolt along with any D44, too.It's closer to their actual worth. I turn down offers to buy complete 3/4 tons for $500 if they have semi floaters.
Martin
Not necessarily. Camaros came (optionally) with 12 bolts and leaf springs.
Martin
