What do you need to do for BB12?
Nice that has come a long way since I saw it a couple years ago. I hope I can make it out there this year to see it again
Wow a 60 w/ 37s and no scratches in the paint...what a shame!
I just gotta make sure my phone is charged...
So i can get on here and look at all the pics of you guys having fun at BB :doah:
looks great Jack, so sounds like you've given it a shakedown already then huh?
Man, the poor General is going to get left in the dust. I'm still carb'd running an NP241...
Just noticed I need to build a right front lower link. Could not figure out why the steering wheel was off 90 degrees. Wheeler Lake trip last weekend did it in. Hit a rock with the right front. Bent the bead lock and bent the link. Oh well.
Steering system Hydro assist, Anyone coming from TX
D60 Build SLOW go
Tires At least one could use some help if anyone has a 37" BFG to get rid of
Cage NIce wish
Engine Wireing OUCH
Exhaust UHHHHH HElp
CB R&R
test PFFFFT
Clean PFFFT
MONEY anyone have some they can share LMBO
Doors Bulid new ones Better ones
Lights Gutted the Old ones/new ones R&R
Winch Repair
Horn
E brake
Tune Up
Guages Oil Pressure and Temp R&R
Pack
Bolts for Front Drive Shaft... Missing
Replace and Up Grade HardWare for Shocks
Umm let's see
finish frame swap
Rebuild engine after I found out yesterday I had water sitting in it??????
Divorce lol jk but that would follow me going to bb
$2000 worth of gas
Everything else is ready
So things have changed.
New fuel pump in wife's new to her car.
Remove all front sheet metal off of the Jimmy. Pull the engine and all the crap that goes with doing that. Remove engine mounts and cross member. Push the frame back into shape on the right side. Plate the frame front and back of the mounts on both sides to repair the broke frame at the panhard bar mount.. Build new engine mounts. Build new cross member. Then reassemble the whole thing. Did I mention I no longer have a shop or garage. My brother is kind enough to let me use his barn for most of the tear down. Then drag it into his shop for the fabbing.
And finish the semi. I guess I had better get off of here and get to work. Tomorrow.
Paint and assembly (of the bike):pimp:
