What gears do i have
84CUCV
3/4 ton status
NJ for now
Well, got off my butt and pulled the cover. these are the #s from the ring gear:
2gm39885151041481
i have no clue how to read that
thanks
i did leave some space out. didnt think it mattered. Should there be more #? thanks
please copy it as it is on the ring gear. and dubble check it. i tryed to find any combo with what you had and could not.
OK here ya go...
2 gm 3988515 10 41 4 84
that is all that is on the ring gear.
thanks for the help
2gm39885151041481
thanks
1041481 = 4.10's BLT 4 81
2gm39885151041481= 3988515 10 41 4 81
Manny
K5MONSTERCHEV said:
Just count teeth and divide ring by pinion.
x2
I looked at mine and there was the faintest mark saying 410. Figured there be more numbers and letters like what you had. Counted the ring and pinion (twice to make sure) and it ended up being 4.56
atho said:
without removing the carrier, how exactly do you count pinion teeth? I guess i'm not that patient:confused:
I jacked up the rear and had someone turn the tire while I counted I think. And also made a small mark to remember where I started counting
Theres no need to count the teeth. You have 4.10 gears. Your axle was made in april of 84. Ive seen so many of these ring gear stamps.....the instant I looked at your initial post with all of the numbers not spaced out I knew it was 4.10's. Counting the teeth on the pinion is a pain in the a$$
-Harrison
