going deeper will make it like a rocket ship on take off. say good bye to the rice burners.
65 mph thats 1300 rpm. in stock form.
sbc like to be in the min 1500 rpm range. but realy do good in the 1800-2200 rpm range. gets them in the power band.
but for now 4.10 and 35" tires you will be just under 1800 rpm. a lot better but on the edge of good sweet spot.
best i would say for now is bolt them in and run them. get a trans temp gauge kit and keep a eye on temps that kills the 700r4 also.
can install gears later if you need.
and if you got the rear axle from a true 1 ton truck you need to move the spring perches and shock tabs to match the 1/2 - 3/4 ton widths. easy job to do.
and if you want new spring perches and shock tabs with ubolts and top plates included all in 1 kit look here
http://www.ruffstuffspecialties.com/catalog/14BSS.html good vendor and super fast ship times.
the front will bolt right in basicly. just swap the calipers from the 1/2 ton out to the ones on the 60 front and blead the brakes. hope you got the top plates for the springs also on the dana 60 diffrent than 1/2 ton. if not then easy same vendor i linked sells aftermarket set. just no sway bar hook up. if lift springs take it off anyways you wont need it. most everyone here has tossed that thing.
you have found the best site for these trucks and welcome.
