rompinstompinmudmonkey
It looks like the rear is sagging lower then the front. How much weight ya got there on the 5th wheel? Your bigger tires takes away a lot of HP that could have been used for better towing. IMO... I don't classify it as a truck.
Let's add #16: A Real truck has a winch![]()
The tractor weighs 12k and the trailer weighs about 7k, so with about 4k of tongue weight I'm ok with squatting the rear a couple inches. Also, my tires match my gearing perfectly, if i went with shorter tires I'd have the motor wound up too high to be able to tow at speed. Right now in 5th gear at 70 mph I'm at 1800 rpm (right at the torque peak of the cummins)
I built it, i use it, and i love it. It does exactly what it was meant to do
