On my second rebuild of the same t-case. My goal of not going crazy with RTV didn't serve me well the first time, so had to yank it out to re-seal it.
Unknown quantity 241, but looked good inside when I tore it down. No issues I saw when I opened it.
First rebuild (after installing the JB SYE kit) I noticed that it didn't like going into 4 low. Just wasn't there most of the time, figured it was adjustment of the shifter. Didn't have time to test it much. Took it out for a weekend, never used 4WD, saw the leaks and yanked it out to re-seal it.
Second rebuild I took as much care as the first, just more RTV. Put it back in, played with the shifter, adjusted it to where the detents matched up with the shifter pattern pretty well, and tested. 2, 4 high, and neutral work correctly. 4 low grinds. I adjusted the shift rod multiple times, shifted by hand, it will not go in gear, even with the shift rod adjusted for maximum force into 4 low. Shifter now bottoms out in the case instead of the shifter assembly, but still just grinds.
As GM decided by 1991 that no one needed to see inside a t-case, I don't have a manual to really look and see what I did wrong on assembly. I feel I followed the JB instructions to a T, and paid close attention to the orientation of everything, but it's pretty obvious I am the variable that caused this issue. My internet is worthless, I'm lucky to be able to view CK5, so videos are out. I recall one of the shift collars(?) could be installed upside down, and that would cause an issue, but I don't remember what the symptoms of that would be.
So BESIDES me being an idiot, what is it?
