Whatchya building for BB16?
Discussion in 'Blazer Bash' started by mrk5, Feb 23, 2016.
  1. r3dd0g
    r3dd0g 1/2 ton status Premium Member
    Sep 14, 2006
    1,329
    1,225
    Chandler, AZ
    Build(s):
    5
    If you've been doing some serious offroading, you probably smashed your springs and deformed your bushings. Buy a new set of springs+bushings+ the little spring washer and when you install it, put your old spring washer and the new one in (one on each end of the spring). This will put a little more tension on the bushing and help it last longer.
    noJeepshere and skunked like this.
  2. ktmoutfront
    ktmoutfront Being right all of the time is exhausting Premium Member GMOTM Winner
    Feb 20, 2007
    14,067
    7,830
    Not where I want to be
    Build(s):
    3
    Finally got into looking at the leaking transfer case issue that kept me off of Fordyce.
    4 bolts from the adapter to the transmission were really loose. I would call them backed out.
    Easy fix. Just normal stuff to look over now.
    Babaganoosh likes this.
  3. Bent77
    Bent77 Black is the new Orange Premium Member GMOTM Winner
    Dec 3, 2002
    17,924
    19,068
    colorado
    Build(s):
    What trails are you going to run?
  4. ktmoutfront
    Feb 20, 2007
    14,067
    7,830
    Build(s):
    3
    Not sure. I clicked some and typed in my CC number.
    BlaZeus and ChrisPerry like this.
  5. Bent77
    Dec 3, 2002
    17,924
    19,068
    colorado
    Build(s):
    Close enough
  6. mrk5
    Apr 20, 2004
    15,202
    4,647
    Northern Colorado
    Build(s):
    Had the exact same thing happen a year or 2 ago. Might need to add that to my bolt checklist.
  7. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    11,693
    9,192
    Toe-peek-ugh, KS
    Build(s):
    3
    I just had it happen to me earlier this year.
  8. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,837
    8
    Grand Junction, Crawlorado
    Building nothing... Everything on hold. Ugh. No money sucks. But I'm ready to see all y'all
    skunked and Bent77 like this.
  9. mrk5
    Apr 20, 2004
    15,202
    4,647
    Northern Colorado
    Build(s):
    Your building your anticipation
    TDAWG1 likes this.
  10. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,871
    81
    Grand junction CO
    Looking like i may be in a jeep if I don't just cancel my trip
  11. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,183
    424
    Colorado
    Drove my POS around the neighborhood with the kids this afternoon. New water pump, thermostat, power steering pump, battery and an oil change done. Need some grease in the driveshafts and put some body panels on.
    Might even do a shake down run next weekend for giggles.
    TDAWG1 likes this.
  12. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    11,940
    1,953
    Hooper, Utah 84315
    Build(s):
    3
    I need to grease my truck too.
  13. TDAWG1
    Jan 18, 2005
    2,837
    8
    Same here
  14. noJeepshere
    noJeepshere I Drive Trains! Premium Member GMOTM Winner
    Jan 2, 2003
    9,344
    2,019
    City of Sand, UT
    Build(s):
    Need a new distributor, since they only seem to last 2 years on this thing, it's a known problem with this motor. And I'm going to replace the upper kingpin bushings to hopefully solve my death wobble. Me no likey shaky steering wheel.
  15. Truckman4life
    Truckman4life 3/4 Ton Status Premium Member
    Feb 17, 2010
    2,546
    2,510
    Cleveland, UT
    Build(s):
    4
    I think I'm going to wax my truck this weekend! Installed new belts and charged my a/c today, it actually works fine. That means every single thing works on my blazer works except the windshield washer pump.
    blazinzuk likes this.
  16. Babaganoosh
    Babaganoosh 1 ton status Premium Member GMOTM Winner
    May 30, 2007
    11,804
    4,265
    Phoenix Arizona
    Build(s):
    I'll be switching out my rear springs on the tahoe, has a saggy ass and sways on the highway.
  17. skunked
    skunked Orange Block Because Chevy Premium Member GMOTM Winner
    Feb 27, 2013
    12,345
    11,917
    Placer County CA
    Build(s):
    put in Z71 Tahoe springs if you're doing that.
  18. Babaganoosh
    May 30, 2007
    11,804
    4,265
    Phoenix Arizona
    Build(s):
    That is exactly what I did.
    skunked likes this.
  19. Bent77
    Dec 3, 2002
    17,924
    19,068
    colorado
    Build(s):
    Had a girlfriend like that once...
    BlaZeus, 72gmck5 and skunked like this.
  20. mrk5
    Apr 20, 2004
    15,202
    4,647
    Northern Colorado
    Build(s):
    Don't forget if you run AC on the trail you have to wear the pretty princess tiara the rest of the day....
