Whatchya building for BB17?
I dont have anything planned at all, it is a doing stage and done for some of it. Maybe just got a bit bigger of a plan though.
Not completely sure the known list
Alternater
Water pump serp belt
Hubs
Diff service
Rewire e fans
Haven't driven it yet so could be more
Winch bumper /winch ?
Hydro assist?
New tires?
Anything else that may show its face once driven
I thought of this recently and this will be my must list that will get done no matter what cause it will only cost about 100 bucks cause I have most of it.
Install my new trans
Oil change
New oil psi sender.
Trans cooler
Front bump stops
front limiting straps
Cb radio
Receiver hitch
Radio and speakers
Aux fuse block
Rock lights
Front aux driving lights
Rear backup lights
Hub caps
All of this is in boxes waiting. I just have to buy trans fluid, wire, and plating for the bump stops.
I pumped the tires up today. And replaced the right front caliper that broke the casting. Replaced a rusty bolt also.
Are you going to resolve the issue with your self-destructing brake fitting? It seems like adjusting the panhard bar length would probably keep you out of trouble in the future.
