4xcrazy
3/4 ton status
Yes, both belts were removed and engine was started, noise was still there.
Well, now you get to pull the heads, and the front of the motor in order to remove the cam and lifters.
http://www.autoserviceprofessional.com/article/91504/Hands-on-with-GM-LS-roller-lifters?Page=4
I understand what you're saying about the cam swap, by not needing to pull the heads, they mention that in this write up, but to change out the lifters, the heads need to come off, I can leave all intake stuff alone apparently.
And honestly if I'm going to go through with the trouble of removing the heads, I'm going to go ahead and replace all the lifters with new ones, in the hopes of getting more life out of it.
Trying to decide now, if I want to go ahead and toss an RV type cam in it or not,,, any opinions?
