I searched around and couldn’t find enough. I have a bad wheel stud up front.. and frankly the other studs don’t look so good. What is the process to change the wheel studs up front? Standard 10 bolt / 6 lug.
Do the hubs needs to come out to change the studs?? I know how to change the hubs ( just did this last week) I guess I’m lost once you get behind the hubs where the big 4 prong nut is in the back. I know it needs a special socket.
Also – I guess it’s a good idea to give the wheel bearing some attention while I'm in there? What is the process here? Is it just easier to buy a whole new wheel bearing assembly with the new bearing already pressed in ? I’m sure they need some attention too.
