Where is the ALDL connector?
Hubnut
Gainesville, FL
I read through as many old posts as I could. I can't seem to figure out WHERE the ALDL connector is to test why my truck has developed a high idle. Would this code thingy be a good place to start? No check engine light is on. Thanks.
It is located under the dash by your left knee. If you take a look it will be staring right at you.
Thanks banana avatar guy. I'll look for vacuum leaks tomorrow. Thanks 4x4high, I'll look for the AlDL connection by my left knee.
haha i have no idea how i ended up with the banana... but anyways. spray some brake clean or such around the throttle body, vacuum lines... listen to idle. ive seen this symtom many many times
