NEK5
3/4 ton status
I`m just wondering if there is anyone else out there that KNOWS they have rot, and just repair the structural stuff, ie rockers, cab supports, rad support, tail pan, etc, and focus on having a strong, solid, reliable drivetrain?
The reason I ask is, I know theres more rot on my rig. I`m sure sooner or later my rad support will have it. Then, because we really only did a good enough job to get by on the cab floor, (ie. the metal that was good at the time that we left to have a place to weld, is now rotting), within a year or so, it will most likely need to be redone.
Now being my DD, and the fact the we can have some pretty bad winters, as well as the heavy amounts of salt we use around here, its bound to happen again, so I just can see spending not only the $500-$1000 to do it the right way, but the countless hours that would go into it.
So, I`m wondering what you guys do. Care to share?
Ben, your best bet is to fix the major stuff and drive it as little in the winter as possible. Buy a beater to drive in the winter.
paint them right away, or use a sealer. Im not certain if galvanizing spray works, but I use it quite liberally- and it seems to hold up quite well.
Learn from me don't go cheap
