Another thread made me wonder, how many of you guys have welded up your axle tubes to keep them from spinning in the housing?
That why you take all the weight off of the axle first.we did this to a d70 with a torch and warped the axle...since we have done it to a few sterling rears and now we have a large oven made for preheat
why the rags? or damp blanket?
i understand the pre-heating, but not the blanket? i would think that heating it up with a torch again would work well for post heat treating???
but im just a canuk so i need some educatin,![]()
My 14bff is basically trash, so when i get another one, ill do the weld tubes trick. Kinda waiting for the tubes to twist, will give me an excuse to get it done.
The housing is cast steel, no need for Ni-Rod. You think the factory rosette's are Ni-Rod?
Pre-heat to ~200 localized at the tube housing area, weld, wrap...have a beer. 350 not only isn't necessary, it'll cook the bearings.
Rene
Thats what I thought when I read 350Pre-heat to ~200 localized at the tube housing area, weld, wrap...have a beer. 350 not only isn't necessary, it'll cook the bearings.
Rene
