I never assume someone new doesn't know their stuff. I respond when it's clear they don't, specifically in this subject.
If you were to search back through the 8 1/2 years I've been here you'd see that more than 2/3 of my ~25,000 posts have been helping guys out in the Garage, the 73-91 forum (before there was a Garage) and the diesel forum. That doesn't make my opinion mean any more, and it doesn't make me an expert...but it does make me someone that is willing to take time out of my day to help someone else out. It does not make me a posting whore, and you'd be very hard pressed to find any reply of mine with the word "pad" in it.
Regarding the welding/fabbing etc. I offer my advice and knowledge because this is what I do for a living. I have 22 years behind me, 40+ hours a week in a very broad variety of work. I've fabbed and welded a ton of stuff for Boeing (777, 787), Lockheed-Martin (Joint Strike fighter), Fairchild-Dornier (when they were still around) Gulfstream, Raytheon (Spy3) to name a few...and I've spent my time doing meat and potatoes stuff as well. I've certainly run into my share of oddball welding, dis-similar alloys, Cast iron, Cast steel, 4140 ,4340, Aluminum, stainless, even A2 tool steel, every grade of mild you could imagine, plate welding up to 6" thick plate, down to 22 gauge. I've done my share of structural, HSS, X-ray tested welding on alloy, worked to AWS code as well as CWB code for the majority of my career. Name a wire, or stick rod out there and I can almost guarantee I've used a few thousand pounds of it.
When i see someone recomending quenching a cast anything part after welding I feel the need to reply. When I see Ni-Rod being offered up I feel the need to reply. When I see someone flinging a bit of mud my way I feel the need to reply.
So, would you like the rest of my resume before it's OK with you for me to offer up welding advice...or are we OK now?
Rene
