Who Is Running a 4L80
Bet that works pretty well with the diesel. Got any pics of the Sub?
fyi t400 to 4l80-e only gets you overdrive and lockup .
same 1-2-3-r ratios inside.
not like a 700r4 low 1st .
ohhh interesting
how about a 4L65?
And how is everyone running a speed signal off the 241? Not an old school pulse generator? :confused:
ohhh interesting
how about a 4L65?
My 241 is electric. Otherwise I would use the the signal adapter.
Mine is an electric output, i'm using both sensors in the transmission and using the transfercase vss for my speedo. Only because my PSI Conversion harness wasn't built for a 4wd.
700r4 / 4l60 / 4l60-e / 4l65-e se trany just newer guts beffy were it needs it . for the simple explanation .
4l80-e guys some times find it easyer to do 2wd tranny with both speed sensors in tranny so it thinks its 2wd .
So to run one behind a 350 2 pc seal with a '90 241 case what do I need?
