Who's in the mag for TTC????
Hey Dan arent' you kinda stacking the votes here!??? ;) You gotta bring that badass atc70 hiding in the background to chase wild boars with. I went with Brian in '01 and those things were everywhere after dark!! Anyways specs on my rig - with a pic with the money green sheetmetal
- 70 burb narrowed 20" at the grille, 12" thru the cab, 30" at the rear, no roof
- 5300 lbs - 2500 rear axle, 2800 front
- all aluminum 383 with commander 950 injection
- nv4500, ord 203/205 with 205 clocked, triple sticked, flat skid plate
- 60 front with 5.13's,arb, 35 spline chromoly thruought, hi steer with assist
- eaton rear with detroit andd 5.13's
- 44 boggers on 15x12 trailreadys with 3/8 plate centers
- 8" 73 up front skyjackers, 56" rear 4" skyjackers, 2.5 swaways ( rear 4 link soon)
- receiver mounted 8274
- shiny green paint !!
cornfed what do u mean by eaton? is that a custom rear axle? ive never heard of it
u already got my vote i was just wondering if u could please explain it
thanks good luck if u get in!! awesome truck!!!
Th eaton rearend is technically the HO72. It came factory in 3/4 and 1 ton GMs from '46 to '72. Its a full floater axle with a drop out 3rd member and removable cover. Its course spline axles and available from the factory in 4.10, 4.56 and 5.13 ratios and factory detroit lockers as an option ( called a no-slip ). Its cheaper to buy complete rearends than replacement parts as they're outrageous in price. 14 bolt disc conversions are interchangeable and some guys swap out the axles and locker for 14 bolts pieces too, I dont know why you would want to though:D
bigbird4wd said:
Boy, that thing is beat compared to when I saw it last May. Now I am glad I built this K5 sans fenders and doors!
Actually it's just a different color. Depending on how you look at it, there actually are LESS dents in it now than there were in May of 2004, since the majoity of the dents came from a flop in September of '03, and I have since replaced the bed.
