Will it fit?
firefighterco2
Hopewell, VA
I have a set of 35x12.50 bfg all terrains on stock wheels right now and I was given a set of 15x12 wheels. Will a 12.50 tire work on a 12 in wheel and will it look ok?
I've seen 12.5's on 12" rims before. They do fit but they look more like the beaner setups. Personally, I wouldn't go wider than 10" for that tire size.
I know the backspacing is correct cuz the PO had these wheels on the k5 with 35x17.50 tires. I really don't like the bubble look on the stock rims so I think I'll try them till I find some other rims or some bigger tires.
12's would look much better on 17.5's.
A good rule of thumb I go by is to not increase the sidewall more than the rim by 2".
