MassMan
Well, spring's finally here, and i managed to finish off the Goodwrench crate 350 in my 85 K5 last week, so i figured it was time to start her up. Over the winter i did the following:
-new headgaskets, intake gaskets, etc
-new plugs, wires, distributor (HEI)
-exhaust was fixed (idiot PO welded the pipes to the headers)
-new belts, fluids, filters, and such
-new valve cover pressure plates and studs/retainers
-wiring straightened out, all remnants from A/C taped off and bundled
-new ground strap for engine, new horn, new controller for electric fans
yesterday i filled up the tank, double checked the connections and battery voltage (14.3v) and cranked her. the starter was extremely sluggish and slowed down rapidly. the seat belt light on the dash dimmed to almost black, the volt meter dropped, and i gave up quickly. checking the voltage, it had dropped to 11.3v. gas was in the filter (clear), and everything seemed fine. i tried it again jumper-cabled to my dad's running truck, and except for a stronger sounding starter, nothing changed. I hooked up a timing light, and there's spark to every cylinder.
checking out the starter wires, the ignition "S" wire looked bare near the starter's terminal, so i decided to pull the starter. the wire had a good 3-4" bare on the starter end, and all the wires looked corroded. i cleaned all the terminals, cut off the bad end of the "S" wire and put a new connector on it. replacing the starter, i tried it again while connected to the running truck. except for a stronger-sounding starter sound, nothing.
after noticing that the oil pressure was shooting up quickly (to about 45psi or so) while cranking, i wanted to make sure there wasn't a problem with the oil getting where it needed to go (wrong head gaskets blocking the passages? i dunno...) i pulled the valve covers and distributor, and turned the oil pump with the old dist's shaft. oil was slowly oozing over the rockers from the studs. is this right? i have no experience with engines, so i'm just assuming that's correct. also, when i stopped turning the oil pump, i heard a small whine/squeal like pressure was being let off.
so, my question is, what did i screw up? the thing ran fine (except for the blown head gasket) until i tore the heads off. i disengaged the shifter linkage and manually turned the transmission to park a while ago, and checked that as well, just to make sure i wasn't adding any extra load there. it's as if the starter's turning a load far to much for it. i just know there's some small thing i'm missing, i just don't know what.
