MassMan
well, it's got a Holley 80457 with electric choke. the choke never moved as far as i could tell, except to let out a puff of white vapor when the engine died.
i'm currently trying to start it while jumper-cabled to my dad's running truck, so it has plenty of juice. i tried the timing light while just cranking, but the strobe was so slow i couldn't make out the timing mark. i guess i should go back and try that again.
i didn't put new studs in, just pulled the rockers and rods to remove the heads, then put them back, tightening the nuts until i couldn't turn the rods with my fingers, then added another 1/2 turn (for each cylinder just rocking). i re-did the rockers twice to make sure i did it right (wasn't quite sure of the whole "turn with your fingers" thing), and i'm sure i did. other than wire-wheeling the valve faces with a soft wheel on my dremel (heavy carbon deposits), i didn't touch the valves. could i have screwed up the valve train?
