Thanks everyone. She moved under her own power this weekend for the first time in a while, with only a front driveshaft installed. toured the block 4 or 5 times to test the brakes.
More projects. Back almost done, front saved till after warm up.
Will have 4 huge recovery points as well
Bumpers are just finished and gonna look Shaaaweeet when they are attached and rhino-lined on the Jimmy.
The front is strate in the middle section and angles to match the grill on each side. The little stinger is angled forward to match the grill as well. Its all 3"
The rear is just strate. Will post pics when I get them mounted, painted and with the recovery points.
The ragjoint should be the same on 2wd and 4wd boxes of the same year. It sounds like you got a different year.
I don't know the part number but I know new rag joints are crazy expensive. You can use an xj shaft for way less money and much tighter steering if you can fab the connection a little. You can also get a custom borgeson shaft to do the same thing.
Really...Ok thanks. I had heard they were different sizes b/w 2 or 4wd boxs, but I never tried to mount the old rag joint because it had exploded anyways.
I used a 71 Jimmy 2wd box in place of a 71 Jimmy 4wd box. At least as far as the parts computer at Napa was concerned.
I will grab one from Borgeson or Flaming River. Thanks for the advice!
The 4wd box was a 36 spline 13/16", the 2wd box is the same except it does have a flat side which removes like 6 spline and makes it a 30.
Have a question / concern for you pros about the passenger side spring perch / studs.
I hope Burt4x4 doesnt mind me using his picture for comparison to mine. He has a front 60 in his K5 as well (first pic)
I had to use like 6 washers in mockup because the thread ended that much higher on the stud than where I needed to go to get tight on the spring plate.
Also it is difficult to get the plate square when there is a gap b/w the spring perch and where the studs are.
hard to explain but look at these 2 pics. It seems to be working fine the way ive installed it, but I want it to be correct (safe)
I think I have some sort of extra long studs in mine from someone before me who had a really thick spring pack or shims?
