Bell housing bolts.
Easy with a body lift. But those two always give me a hard time. Especially getting the one back in along with the tranny dipstick tab.
I've had my trans out like 4 or 5 times now.
The best way to attack those is to remove the trans cross member and lower the back end of the trans down some. This rotates the back of the motor down about an inch. With the motor and trans in that position I use 2 inch 1/2 extensions with a swivel on the end and a socket. Connect that to 1/2 air gun set on #2 and zip them out. Putting them back in is pretty easy. You can get your hand up between the trans and the tunnel to start them.
...I think I did ONCE..
