YeeeHaaaaaDOUBLER!!!!!
I got the crossmembers figured out last night.
All factory stuff I already had layin around. The last thing to do before ordering driveshafts is to cut the spring pads off the 14b to point the pinion up a bit. Might locate the axle back 1.5" too. Gotta modify the front x-member for drive shaft clearance and the doubler project is done. :grin:
I like the way that looks ! I am about to start on mounting my 465/203/205 set up and that is what I had in mind for the rear crossmember too. I have got a lot of spare dual cross member skid plate OEM stuff and plan to do just what you did .
Looks great !
Tom
It's pretty simple, all I had to do was drill a few holes. I already had the bolts left over from the beadlock project. Post up pictures when ya get yours done. :D
