yes i searched cant find it whats gears were in 89 k5s with 5.7 lt 700 r4
LargeMouthFeaver
BODYMORE MD
As title says cant find it anywhere on forum. My truck is a 89k5 was a original 5.7 lt 700 r4 combo silverado model . whats gears did they come factory with. i cant find the info anywhere. all i find is info on 87s
You could have pulled the cover and checked it yourself in less time it took to post this.:D
i dont no y i didnt think of this but you can get under the truck with the rear axle jacked up and mark a spot on the yoke and have a buddy spin the tires 1 rotation(make sure u get close as u can to 1 rotation) and u count how many times the driveshaft spins and say it spins a tiny bit over 4 times and the tire spins 1 time, you have 4.10s
my running buddy has same setup 89 k5 350/700r4 he is running 2.56 gears and oldly enough im running 85 k5 305 (blow up friday) 4 speed and also running 2.56 he does good on gas but could use lower gears for more torque.
<----- '89, Suburban, TBI 350/700r4/np241 and 3.42 gears (stock) of course, now running 4.10's, and still need more :crazy:
had a buddy that owned an '87 Burb, his had 3.73's, along with another friends i think 86 blazer with 3.73's.
personally, i think the higher probability in gearing is going to be 3.42's or 3.73's, but the only SURE way is to pull the cover and find out.
2.56 was a car ratio lots of midsize small tired a/g bodies had them , 2.73 was the highest 10 bolt ratio in a truck , and gone by the mid 80's , but don't quote me on that :wink1:
Most common after the mid 80's were 3.08 , 3.42 , 3.73 in a K5
i think its probobly going to turn out to be 3.08 since i had the exact same setup and same year blazer and it came with 3.08
