yukon axles on a 10bolt
Depending on where you live and what you wheel a half ton can work for awhile. The bearings and balljoints will need replaced more often. It's his experience not yours. He just was relating his truck and how good it can work. Will it run as long as a 60? Never. But not everyone wants or needs it. As for unsprung weight unless you are jumping it, you won't feel the difference. The springs and shocks control up and down movement of your cab not your axle. Unless you are off the ground and coming down on said springs and shocks with the extra weight pulling on them. To the op: glad to see your axles lasted so long. Keep an eye on service parts like steering links ball joints and bearings. Those 39.5 inch tires will wear out the 10 bolt pretty quick if not taken care of.
