should the bolt for the zero rate be grade 8?
Ahh, so you used the zero rate to move the axle. Well, grade 5 should be fine, but I doubt it would hurt to run grade 8.OK maybe not to clear. the ord zero rate comes with the center pin that you cut down if using the offset hole and then a bolt to go through the zero rate and the spring pack. the bolt they sent is grade 5. just doesn't seem right.
There has been debates on this board before about the Grade 8 vs. 5 spring center pin.
The end of the debates are that a 5 is what is standard in most if not all springs and or "kits" that you need to disassemble the spring pack to install. To the best of my knowledge there is not a Grade 8 center pin made.
Some feel that a Grade 8 helps to keep the axle in place. Some feel that the u bolts are what hold the axle in place and the centering pin is for lineup during assembly as well as holding the leafs together when out of the vehicle.
If you want Grade 8 you will need to use a bolt and trim the head down to fit.
I feel that the supplied centering pins are fine. They don't so anything but hold the pack together and locate the axle until the u bolts are tight.
Grade 5 bolt, not so good![]()
Lots of people in the race industry like running grade 5 over a grade 8 because a grade 5 will bend giving you an indication there is a problem whereas a grade 8 will just break.
I myself like using grade 8 for EVERYTHING when i can. Also for use as a centering pin on a zero rate you can use an allen bolt as almost all allen bolts are grade 8.
my spring pin is a allen head screw.no problems.
As it should be.
Factory spring pins aren't allen head, they are round head and just have a slot in them.
