My ability to tinker on the truck is kinda slow cause of work stuff...we'v been doin this little bull **** field problem for the past week, still have a week to go. Stuck livin in the motor pool 24/7. I only get the chance to do anything when I can sneak out to the parking lot and at night.
When I get a chance I'll go pull the governer cover and look in there...although still not real sure what I'd be lookin at. I would have replaced the modulator already, but autozone didn't have one. Is that a parts store item or..?
It has good strong vacuum at the modulator, so I know that line is good. I guess the next step is to find the shift solenoid hing and take a look at that. Also inspect my throttle cable/linkage...it's always had a small sticking point right off idle. Maybe the mud/sand exagerated that problem.
For the governor, there is a cover held by a rod style clamp (best description I could come up with) when you remove that clamp the cover can be popped and slide out the governor.
The governor has some weights that will open up on centrifugal forces or if you just move them with your hand, those hardly ever have a problem, but they are attached to a valve inside the unit, and it somtimes can get stuck.
Wiggle the thing and try to move things and make sure everything is free to move.
If the wieghts open up but the valve doesn't move up and down then you have a stuck governor.
It's litterally a 10 minute job from the time you get under the truck till you put the clamp back on.
If you really need to, Summit has 'em. They have a shop in McDonough at exit 216 off of I-75.
. But, look on the bright side. You are about to become an expert!
