I'll try and do a better job documenting the build process, Part numbers, vendors and process of this K5 build than I did when I built my Nova.
Bear with me as I've never done a build thread and I'm usually too busy working to think about taking pics and documenting the process.
- 1972
- Blazer
- Unsure
- Modern take on original
- Unsure
- LS3
- 4l80e
- NP205
- Stock
- 2" lift
- Stock
- 15" factory ralleys powder coated
- 33x12.50x15" BFG AT's
- None yet
BPE LS3 530HP/495 ft lbs. of Torque, 4l80e, Np205, stock axles front and rear, 3.73 GR, older 2" lift with blocks in the back, New Tub with single wall top, original frame, front fenders, hood, and cowl.
Notes
Body and frame have been separated, frame has been degreased and needs to be blasted/powder coated. New tub with top will be picked up June 2024.
