THE STUBBY project / R.I.P . . . . . . . . . . .
more info at post # 333 link to diy4x custom dash build for the truck.
i have a 88k30crewcab body is a bit beat. box is shot in all the wrong places. then cab corners little shot along with some spots in rockers. front fenders need replaceing.
so i got to thinking i need a party truck and dont need the length. so i want to take crewcab and make super short play toy like these. thinking more like mtmikes in the last 2 pics.
any helpfull hints would be vary usefull.
to those who have or helped with this kind of build and moved the spring hangers up the frame. how much lift did you get alone if any. this will help me preplan parts needs.
plans are move hangers up the length of frame rails. then chop off the rest. mini flatbed on rear. 38" ground hawg radials. ord crossover steering and detroit rear with spicer power lock front. stockish 350tbi with 4l80-e/241 adaptor/203 range box/ord doubler kit/205 remaned & twinsticked/high angle driveline flangesalong with 5.13 gears.
pic 1 stock truck
rest is gathered from here for ideas.
thanks to those trucks i have posted pics of thay look great.
1988
gm
k/v 3500
More from sweetk30
Daily Driver The 1961 c-10 story
99 LS1/6SPEED SWAP in a weekish
sweetk30
2,599
8.1 bbc vortec / nv4500 / 4.63 rear 1.5ton truck was a 12ft flatbed dump now 10ft flatbed dump .
sweetk30
1,720
start of the rebuild :weld::grind::hack::truck::1zhelp: 04/3/15 post 61 ---------------------------------------------------------------- the life & times of my k30 plow truck first few threads on the truck from the start to now. basic's of the truck from start :http://coloradok5.com/forums/showthread.php?t=209912&highlight=plow 35" tires : http://coloradok5.com/forums/showthread.php?t=252004&highlight=plow rim refurb ...
sweetk30
1,426
1985 c-10 2wd with 5.3ls / 4l60-e / 3.73 Detroit true trac rear . 12/17/13 post # 567 little info update 5/11/15 ------------------------------ UPDATE : painted pics of it out in the sun light :thumb: ----------------------------------------------------------------------- time for a new project i guess. ya i have a few but this could be used a lot more and i am tired of my current dd vehicle as its not me. so i happen to see this on local craigslist few weeks ago and then...
sweetk30
1,602
i got my farmer friends 98 ford e-350 strech van to work on. he got this van this past fall used real nice shape. never realy drivin in the winter min rust for upstate ny salt belt vehicles. well the rear bumper was smashed in on right rear corner and also turned up like a twizler is made. so makeing it stright was not gona happen. new aftermarket min 200 bucks and good used not around here. so after thinking it over i am making him a new bumper BEEFY style. pic #1= van its self...
sweetk30
2,335
