‘82 GMC “Junkyard JIMMY” {Build bash Rebuild}
Rear wheelwell tub work
I run a 2 1/2" lift with 35" tires. My rear tire rubs my wheel well when I am flexed out. I decide to tub in inward some to stop the rubbing. Here are some pics:
JIMMY 034.jpg I painted fresh black before my last run to see where I rub.
JIMMY 033.jpg I made a template of the body lines I want to follow
JIMMY 032.jpg I cut it out with a 4" cut off wheel
JIMMY 031.jpg I kept to top flange to have less welding
JIMMY 030.jpg I folded the ends in the bench vise and it begins to take shape.
JIMMY 029.jpg I tacked the bend in place...
JIMMY 028.jpg ... then welded it.
JIMMY 027.jpg ... both sides
JIMMY 026.jpg ... then grinded the welds flush. 1 down 1 to go. More pix to come...:grind:
I tubbed my old K5 for the same reason, but skipped the pain of making the tubs. I found another set of inner wheelhouses, and grafted them to the originals to gain an extra 4" on each side.
48" level on top of the new wheelhouses.
Rene
They are installed. I wanted to keep the back seat so I couldn't tub in as far as you did.
Nice work on the install. My work was not as clean. Pic to come...
Here is some pix:
JIMMY 046.jpg cut out.:grind:
JIMMY 044.jpg Trimmed to fit
JIMMY 045.jpg I had to modify my rear seat tilt lever.
JIMMY 043.jpg Fire watch- weld in progress.:weld:
JIMMY 038.jpg After
JIMMY 048.jpg Before.
I took off the arm rest for more clearence. I gained about 1 inch.
The Test
I went to the High school in my neighborhood & propped the rear end up in the air:
JIMMY 049.jpg Yep it's sunny in San Diego
JIMMY 050.jpg Zoom in
JIMMY 051.jpg This is as far as I could tuck it- No rubbing...
Looks like from that pic the rear shock needs a new bushing. i like the wheel wells. Looks good
Well, that would be a FAIL I need to fix. I broke the shock mount, welded a "quick fix" shock mount tab but didn't gusset it. When I got home after a weekend of wheeling the tab bent & looks like what you see in the pic.
I will fix it soon.
My mistake was I put shocks on it that were too long. I was thinking it would help let the droop out but I didn't think about the up travel. I hit an obstacle & bottomed out so hard I broke the mount.
Under the hood
Under the hood I have a 305sb with an oversize RV cam, Edelbrock 650cfm Thunder series Carb,K&N air filter, Hooker headers, dual batterys, 100 amp alt.
This used to have a 6.2 diesel motor in it but was swapped out by the PO. He found this little gem in a shop where this old timer built it just for fun. I can't believe how much power this 305 puts out.
I still have a huge radiator that was with the 6.2 diesel with 2 oil coolers.
I use 1 for my tranny cooler, any ideas what I should use the other cooler for?
I was thinking hydraulic steering assist...
