Lol as long as fuel can't get past the pressure fit
It came with the needle seats in 06. It was supposed to be a THUNDER SERIES offload carb. It worked pretty good for a few years.Were you running the offroad needle kit?
I ordered new floats. Should be here today.Yah he had the offroad needles.
Idk what's up with your carb Paul, mine seems to run great
Thanks for the chat time Adam.
Have you ever tested your floats? They can go bad and take on gas and not float right. I bought new floats, the rebuild kit, and off road needles.
OK. Maybe I will... I still think your the best " best man" ever!It says "junkyard" in the thread title. Go to a junkyard and get a TBI setup.
Martin
I don't see any reason to run any kind of carb besides a Quadrajet in a truck with a stock motor that's going to be driven off-road. Other carbs may run better or give you more performance on the street, but they will let you down when you're going up or down a hill. Or if you're on a sidehill. I think you can get a q-jet from the junkyard cheap and rebuild it cheap and be happy about it.
I can help out.
