Project "RESPAWN" - 1972 K5 Blazer
Cool stuff here!
A person asked at the bottom of the page. Summit "expert" said ~26" and 1.8" ID meant for 1.75" application.
The one you linked looks a lot like the one I currently have. And i hate it. Absolutely most pain in the butt hose to install/remove. That said its theoretically cheaper per foot.
Hmm, I wonder if the new one you ordered can be bent a little, when does yours come in?
Tracking says tomorrow. For my 86 its a straight shot so no need for a bend. Will bend the one coming and let you know. The one I have now like that Dayco has wire reinforcement and might take a bend better.
  • Like
Reactions: CK5
Do you have a local Parker store? They carry fuel rated hose.
  • Like
Reactions: CK5
I got mine from a local hose supplier. Pretty sure I used exhaust pipe to adapt the 1.75 to 2" though.
  • Like
Reactions: CK5
Did it come in?
Hose seems of decent quality but if you are needing a 90° bend I don't think you want this one. Was already starting to kink with a slight bend.
Got everything plumbed in now, next up I have to clean up the area where the tank was just because. I decided to just use all new parts while I was in there, was thinking I would spend around 350.00 to 400.00 bucks total... so 700.00 wasn't too bad. :doah:
Got everything installed today, used RTV to attach tank felt to the crossmembers and tank straps. Looks like I now have 10-12 PSI fuel pressure instead of 8.5 but still has a miss and not as much power as it should. It is now LS ready and my fuel guage is correct at least.
Other than the melted weatherpack connector, is the yellow piece a mechanical to electrical connector that sends a VSS signal to the ECM?
I have seen something similar with a B&M lock-up kit for a 700R4.
Could it be in this application?
The only thing different is its a SYE tail housing.
