‘83 K10 Shortbed Sally
Family Leftovers…
Fastereddie
Sorry if I offended you. Not.
Staff member
Moderator
Solutions
1
Henderson Nevada
This thread is for the general discussion of the Item Sally. Please add to the discussion here.
Got the 42s on order yet?
Not for this girl. I think she gonna stay stock (looking) She’ll most likely end up getting the 6-lug semi-float 14 that came out of the blazer with the anti-wrap bar.
The main problem right now is the efi pump in the tank needs to come out and put a regular carb style sender in it. I already have a Holley red pump I can use.
This gen v has no mechanical pump provision. It ran “ok” when this engine was in the blazer, just over heated on longer drives. I just want to get it so it’s not sitting and I can drive it around the neighborhood at least.
I almost forgot you had this truck. Happy to see you back at it with this one.
Hey at least it’s a qjet. I’d rather have one of those than an edelbrock on there.
Yeah I actually bought that carb from quadrajet power when I first got the K5. It works well. I still need to hook up the choke wire on this truck for it.
