“Dylan’s” 89. Back at it!
89 Jimmy 6.0/4l80e/MAGNUM 205/d60/14bolt
Ummm... those don't look like KM3's. SPILL IT!
And when do we get one of these
with these ?!?
Oh I forgot. The KM3s kept getting pushed back. I ordered them in February. Sick of waiting so I switched to the new Maxxis Razr in a 37. Should be good for a while until I get some balls and jump to 40s.
Well it won’t fit in the garage with them on so it might be a little bit.
Let me know what works on the roof, I've got the same thing to do but with more surface area
Today I just removed as much of the rust as I could with a strip disc and DA. Then clean and put some Ospho on it. Tomorrow i am going to sand again with some 180grit then hit it with some rust encapsulator, then I’m gonna sand it one more time before it gets primer.
Here you can see a little of what is left of some “patina” surface rust after being stripped and treated and hit with some 80 grit this morning. Encapsulator will go on top of this.
This probably isn’t a lifelong fix but I should get some years out it. This is what some instructional videos said to do anyway. And I don’t have the time, patience or skill to do it the permanent way.
Dang I would almost be worried about that stone driveway! Looks pretty ritzy? How’s the neighborhood?
It’s gone downhill since we moved in :cool1:
I’m gonna cover up the driveway when the real painting goes on.
So when do we get to see some cool wheels?
Dropped them off this morning and they said they were “hours behind” :angry1: after I called yesterday and asked if I needed to make an appointment. I might wait till tomorrow to pick them up.
H2's?
You could have just cut it off and avoided all that work.... :whistle:
