I think so too! I kind of just went with the H2s bc I got 5 for $200 but they really are a sweet looking wheel. And pretty stout. Hate I have to get spacer but oh well
Not if you get a couple of those strip discs. I’m sure you have a grinder. Make sure you get some extra black disc.
After using the aircraft stripper and then getting the remainder with the strip disc I have used 3 disc and countless sheets of sandpaper on touch up stuff.
Here is the progression of the roof. First pic is our starting point. Second was after 2 passes with the strip disk and Ospho, let it set. Third pic was after a pass with 80grit on the DA. From here I covered it with rust encapsulator and I’ll give it one more pass with 180 grit before covering with primer.
Or that could also be read, I have done all I am going to do.
Tomorrow I will start cleaning and taping, I’m assuming that will take the better part of a day so I may just hold off till Wednesday to spray. Once I start that it shouldn’t take but a day or 2
Hoping to get everything taped off and organized today so I can just start spraying tomorrow. Epoxy has 30min flash time between coats, Im assuming base and clear are 30-60 min also. If I start first thing in the AM I think I can get it all done. 6-7 rounds
